Good morning. Sorry for long post, but wanted to provide all details. I am currently having problem with my Victron 100/30 SmartSolar controller not proving watts from my rooftop solar panels to my LiFePO4 batteries on my travel trailer. This has being going on for the last 5 days, and I have yet to come up with a solution to my problem. Previously, this same solar controller was providing great watts to my Lithium batteries.
Whether related or not, I did change out my battery monitor from a previous battery monitor to a BMV-712. This battery monitor does appear to be working well, and the settings are per the battery manufacturer. In addition to my rooftop solar, I also have portable solar panels which are plugged into the same system using a separate SmartSolar 75/10 Victron Solar Controller. Both rooftop and portable solar panels have being working well together on our current travels. Now only the portable solar panels are providing solar power.
Current System
Two 100AM LiFeSO4 batteries connected in series
BMV712
SmartSolar 100/30 connected to 480 watts of rooftop solar panels wired in series (Not working)
SmartSolar 75/10 connected to 300 watts of portable solar panels wired in series (Working)
Troubleshooting Performed
- All rooftop solar panel wires (via MC4 connectors) were checked for proper connection. Solar panel voltage on the rooftop currently show 58v at the solar entry point, and at the PV connections at the SmartSolar connection point. The 480 watts of rooftop solar panels are wired in series too.
- SmartSolar 100/30 is grounded to the entry post from the negative post of the battery (2 ft wire)
- The battery voltage readings from the BMV712 all currently show the same voltage, currently at 12.1 volts indicating the network appears to be working correctly. My multimeter readings are consistent with the BMV readings.
- What I do see on my SmartSolar 100/30 controller is the blue LED is blinking. According to page 38 of the current Victron 100/30 manual, it states “The bulk LED will blink briefly every 3 seconds when the system is powered but there is insufficient power to start charging.” but not sure why the blue LED is blinking. Rooftop solar has been present over different periods over the last several days, including driving under sunlight while moving to a different campground, so there should have been plenty of opportunities to receive enough power to work. The voltage has always been +5 volts to initially start the solar controller, the rooftop solar panels are wired in series.
- As mentioned above, a PV voltage is 50 volts or higher, but no solar power which could indicate a problem with my negative wire connection, but have yet to find an unconnected negative circuit connection.
- All firmware for all Victron devices are up to date.
- I have done maybe 4 hard resets of the 100/30 Solar Controller, removing battery connections and PV connections. Waiting at least 2 minutes before reconnecting the battery wires, allowing a few more minutes to be connected before reconnecting the PV wires each time. Again no change in solar wattage.
- Rotary switch is set to 7 for Lithium
- Unplugged portable Victron SolarController to so system would not see the voltage from the portable solar panels, and hopefully wake up the 100/30 rooftop solar. No change, still no wattage from the rooftop 100/30 SC
- BMV was programed when initially plugged into shore power to ensure Li batteries were at 100%
- All fuses and circuit breakers checked as good
Given the information above, I don’t know if I have broken or ineffective 100/30 solar controller or some other problem I have not identified yet. My Victron Solar controller is about 4 years old now.
Any suggestions on what to try or to confirm the lack of solar power would be appreciated.
Thank you.
Mark
