michaelfr avatar image
michaelfr asked
Orion XS won't show up on Cerbo GX if disabled via Remote L
this is a bit of unexpected behaviour, which I'm seeing:
- I have two brand new Orion XS (FW 1.03 / Bootloader v1.01) connected to a Cerbo GX (FW v3.50~5) via the Duppa.NET USB-Adapter and respective cables
- The Orion's & Cerbo are connected to the same battery and common ground (both have Voltage coming on the IN port)
- Both Orion's have their Remote L wired to a relay switching the L to ground, disabled by default
- When the Cerbo is booted, I log in to the Remote Console and do not see the Orion's unless...
1. I enable the Orion XS via the Remote L switch (reproducibly makes the Orion show up after a delay.)
-- or --
2. I connect to the Orion XS via Victron Connect from my phone (only works sometimes, couldn't find a pattern to this)
I can wait for many minutes - without doing either of the above steps - and the Orion's will never show up on the Cerbo.
Looks like unexpected, undocumented behaviour or a bug to me.
Any feedback?
Thanks,
Michael
cerbo gxVE.Directorion xs
