Hello community!
I have had a Victron Quattro based solar system installed in my house by a Victron approved installer. Recently, a 3rd party electrician expressed concern on how the Quattro was wired in. This is not as per the Victron recommendations. As you can see from the schematic diagram an islanding switch connects the consumer unit to either Grid or Output 1. This creates a loop from Output 1 to Input 1. Also completely ignoring the fact that the system will go off in the event of grid failure, requiring the switch to restore off grid power. Before I go back to the installer to question this I would like to know the community (and official Victron) view on this.
Is this a normal method of wiring?
Is this acceptable?
Is this safe? (possibly Victron technical admin can answer this)
Regards,
Paul
