are there any issues with running an MPPT RS 450/200 vs 4x250/70 for "low power" (~2000Wp total) or will it be less efficient (spec: 96% max. vs 98% max., but would utilize higher voltages/less amps and 1 big unit = less loss maybe?)?
The strings are different panels/orientations, so I need (at least) 4 MPPTs.
I see self consumption would be "a lot" lower (1x15 vs 4x20mA = 0,75 vs 4W) for 1 big unit, but I mostly care about total production efficiency, esp. in low light situations.
Other than that I only see 120V startup voltage vs. Vbat+5V - will all 4 MPPTs produce efficiently if at least one is 120V or does each one need to be 120V?
It seems to me one big unit would probably be better if I can maintain >=120V? Am I missing something?
Thanks! :)
