Im using a Victron system on my boat with a Cerbo GX device. I would like to display tank levels from Fresh water & Fuel tanks as well. The tanks are connected to the EVC system from Volvo Penta and a Volvo Penta (Easy Connect) N2K gateway is installed. The Cerbo GX also have a N2K cable installed and connected to the N2K backbone.
The tank levels are available on the N2K bus as I can see them on my MFD.
Victron devices are also available on the N2K bus as battery info is available on the same MFD.
The Cerbo GX also lists the Volvo Penta gateway under visible devices but I cant see the tank levels anywhere. Do I need to configure something manually on the Cerbo or is the VP gateway simply not supported?
Unfortunately I cant find any detailed info around PGN’s for the VP gateway but the MFD can display the tank levels with no issue.
Many thanks in advance.
