Hi there,
I've got a Phoenix Inverter Smart in my camper (no external power).
I'm using an Orion XS which is not isolated. So the negative of my house battery = chassis = negative of starter battery. After the inverter, I've got an RCD.
I now wonder if I can combine the grounds in the inverter:
- DC Minus
- PE
- Case Ground
as they all are usually wired to the chassis anyway and the larger DC Minus cable ends up there, so there won't be a difference?
