Hi!
The skylla ip65 12/70 was charging fine a few weeks ago, but since the last passage it doesn't charge anymore...
After testing 240v ac before fuse but 0v after and no continuity, I replaced the fuse.
It now has 240v post fuse but still isn't charging!
Batteries 1 to 3 all sit around 11.9v... no current AT ALL going out.
Menu shows charger as "on" and bulk absorb at 14+volts...
I suspect something is wrong on the 240v side. Any suggestions? Anyone faced that issue ?
Thanks!
