Quatro 48VDC 8000VA 1101 Inverter manual includes:
WARNING: DANGER OF ELECTRICAL SHOCK
The product is used in combination with a permanent energy source (battery). Even if the equipment is switched off, a
dangerous electrical voltage can occur at the input and/or output terminals. Always switch the AC power off and disconnect the
battery before performing maintenance. In addition, discharge the battery terminals or wait 30 minutes.
Manual-Quattro-5k-8k-10k-15K-100-100A-230V-(firmware-xxxx4xx)-EN-NL-FR-DE-ES-SE-IT.pdf (victronenergy.com)
Which terminals should be shorted with a resistor to manually discharge the capacitors?
Thanks!
