SmartSolar Charge controller is paired with a SmartShunt and recently stopped charging the battery. It shows the state as "OFF" Battery Voltage 13.32 and Solar voltage 17.7
If I disconnect the solar from the battery the unit will continue to operate on solar - reporting data to my phone.
Once I re-connect the battery it will charge normally until the next day when it will be OFF again.
