I have used the Victron MPPT calculator tool but the different PV connections setting has made a big difference and I don’t know why.
Example 1,
When I put in, 2 Longhi 435w panels (I have a Fiat Ducato lwb so plenty of room for solar) in series on a 12v system with 4mm2 cable over 10m with pv terminal connectors, the calculator recommends a 100/50 MPPT. Hurrah, that’s what I have bought.
Example 2,
However, if I change just the connectors to MC4 and everything else stays the same, the calculator changes the recommendation to 150/60. I note that this recommendation has a MPPT with actual MC4 connections as part of the MPPT
I intend to use MC4 connectors to connect the panels together and run the cables to a 100/50 terminal connection unit. Will I be ok to use example 1 and use my 100/50 MPPT? (Screenshots below).
Thanks
Example 1
Example 2
