home3131 avatar image
home3131 asked
auto switch between charger only and ON ( charger and inverter)
I'm looking for a way to switch my multiplus to 'charger only' during the day and "ON" (inverter/charger) automatically at night. I can do it manually no problem. I have not found a setting to do this. Can I do this using Node Red ?
MultiPlus Quattro Inverter ChargerNode-RED
nickdb avatar image
nickdb answered ·
Yes, nodered is perfect for this. It is easily done with some basic flows.
I have moved this to the modifications section which is where NR questions belong, but as it has a new home (please read the announcement pinned in the section), you would be better of re-posting this on the new forum.
Though I would use the search bar in the old section to find some similar topics.
