seitus avatar image
seitus asked
Connect one inverter to ACin and another to ACout of a multiplus 2.
Dear all,
I have a multiplus 2 48/10000/140. I also have 2 inverters 6500 Wc. I cannot connect these 2 inverters to the ACout output of the multiplus because I often exceed a production of 10kW which would burn out the multiplus. Can we connect an inverter to the input of the multiplus 2 and another to the output of the multiplus 2 at the same time?
Thank you for your help.
Multiplus-IImultiple inverters
Hi @SEITUS,
Yes, You can connect multiple AC PV inverters in multiple locations in a Victron system.
AC PV inverters connected to the AC input require a grid connection, and if the grid is disconnected so will the AC PV inverter. However there is no limit to the size of AC PV you can connect to the AC input.
AC PV inverters connected to the AC output do not require a grid connection, and will continue to work if the grid is disconnected. However there is a 1:1 limit on the size of the AC PV to the size of the Victron MultiPlus (as well as battery sizing limits).
seitus avatar image
seitus answered ·
Merci beaucoup pour cette réponse très claire.
