Hello
In my caravan there is a MP12/1800 with a 12V 100Ah battery. On the roof a quite small PV with an MPPT to load the battery, controlled by a Cerbo GX and a Smart Shunt to measure the voltage/current.
Now I want to extend this setup with a big problem. Because of weight and space problems I’m not able to build a second battery in the caravan and also there is no space for mir modules on the roof.
Now my idea: build a box with battery, MPPT, shunt and temperature control where I can connect additional modules. With a plug near the first battery I want to connect DC and data communication in my caravan.
Now the question: is this possible. Can the Cerbo handle this installation, do I need a second Cerbo in the box or is it still not possible.
Thanks for your time to think about!
Regards
Sebastian
