Hi. I want to connect the mains detector to my multiplus compact 12/2000.On the diagram it looks like the live and neutral cables from the mains detector go into the same AC inlets as the AC-IN live and neutral wires (so for example two wires, both the mains detector live wire and the AC power live wire together in the same screw connector/hole)? Or do they go in a different inlet? Thanks! Nicholas Slater
