I have a Mulitiplus II with an Beagelbone runnung VenusOS. Multiplus an VenusOS is updated today. I installed (sent) the ESS assistent with VE Configure, Grid Code is set to Austria. The Beaglbone is connectec with USB-MK3 Adapter to the multiplus after programming.
But the console shows "No ESS Assistent found". How can I debug this?
What else is necessary to show the ESS Assistant? Can I check something with dbus-spy?
Thanks,
nemo
