Hi All,
I find that if I access Node-red via the VRM menu it times out after a few hours or even minutes and won't reconnect (and I have created a thread about this some time ago) so I prefer when at home to access node-red on the LAN. This works very well and stays connected. My question is how do I access Node-red dashboard via the LAN ? The instructions say it can be accessed locally or via the VRM but doesn't give an address. If I use the usual node-red address I go to the flow editor not the dash. I'm probably missing something simple, can anyone point me in the right direction ?
