alexflibero avatar image
alexflibero asked
temperature battery sensor
I have a smartsolar 100/30, can i add a temperature battery sensor to stop the charge if the battery temperature go high ?
Temperature Sensor
pwfarnell avatar image
pwfarnell answered ·
If you only have e SmartSolar then you can get a Smart Battery Sense and connect the two together with Bluetooth.
If you also have a GX device then you can use a wired temperature sensor or a Bluetooth Ruuvi device.
https://www.victronenergy.com/meters-and-sensors/smart-battery-sense
https://www.victronenergy.com/meters-and-sensors/temperature-sensor-qua-pmp-venus-gx
Victron temperature sensor disambiguation table - which product supports which sensor
