fchurtic avatar image
fchurtic asked
Multiplus output to drive an external LED when inverter is on
Hello victron community, I am replacing a mastervolt inverter with a VictronMultiplus 24 5000. The old Mastervolt was controlled from the yacht’s central panel, which had an LED indicating when the inverter was on or off. I was trying to find out how to connect that LED at the central panel to show when the inverter comes on. I will be using the external switch charger only on off switch that the multiplus has for this purpose, but not sure where I could connect the LED at the panel. Any help much appreciated.
Francisco
led
jetlag avatar image
jetlag answered ·
You could install a 120V/230V "LED" in your switch board and connect it to the output of the Multiplus2 inverter. So if it comes one, then the power to 120V/230V is given and the indicator LED would light up.
Other way is to install some fancy GX device with a screen to visualize all the energy flows and states.
