michael-parks avatar image
michael-parks asked
victron phoenix 24/375 into ac1 of multiplus II
i would like to use the smaller phoenix for smaller loads then have it switch to the larger multiplus II 24/3000 when needed.so im basically treating the 375 inverter as shore power and that power would go to my rv transfer switch then to the multiplus. so if i plugged everything in what is the default way that it will operate? does it automatically switch to the multiplus when i run out of power? or is there some settings i need to adjust somewhere?
also i dont want to pull power from the battery via phoenix and then charge the battery via multiplus. where do i go to turn this feature off?
i also have a cerbo gx hooked up with ve.bus connection for multiplus and a ve direct cable for the phoenix.
software
Justin Cook avatar image
Justin Cook answered ·
No.
Besides being an unsupported configuration right from the start, this simply won't work as you think it will, and will cause you all sorts of problems - and potentially damage your components.
Please talk to your distributor, or consult a reputable and experienced systems installer for assistance.
niklas-schauberg avatar image
niklas-schauberg answered ·
daisychaining a phoenix to a multiplus works in general, but I think the 375 is very small in comparison to your MP. you would have to limit your MP to 1A/230V or 2A/110V max. this seems a bit super low end for me.
why don‘t you use the transfer switch between the MP and the loads?
michael-parks avatar image michael-parks commented ·
my thought was i could charge the batteries if i ever decided to disconnect from the 375 and connect to shore power and change some settings somewhere each time.
how about if i add in a 10 millisecond automatic transfer switch that will switch to the bigger inverter via current transformer triggered by a set amperage. say 340VA or so.
maybe i need to use node red?
my reasoning for the first wiring diagram:
i just thought instead of adding another transfer switch and current transformer that i could just utilize the one built into the multiplus and use victron software to adjust or use node red.
