The system is working well. The problem is just the readout on the VRM display.
- ESS single-phase setup with AC-coupled solar array – 3300 kW.
- ET112 measuring solar energy. Essential loads are not used. Feed-in excess solar charger power. Optimized (without BatteryLife).
- PV Inverter reading is correct.
- Battery reading is correct.
- Nothing is being fed to the grid but it is showing -1563W?
- AC Loads is showing 0.0W but my actual background usage is about 600W.
I believe that the AC Load should be showing about 600W and the Grid should be showing between -50W and +50W whilst the battery is charging.
