Hello everyone,I want to control a total of 3 relays via Node-Red, I've now tried a few things. However, switching the relays doesn't work as it should. Relay 1 should switch as soon as >-2200W is measured on the grid meter. Relay 2 should switch when relay 1 is energized and the grid meter measures >-2200W. The same conditions apply to the 3rd relay. As an example, relay 1 does not switch as soon as the power is >-2200W. What could be the reason?
