Hi.
I have a Multiplus II 5000 charging my home battery, managed through a CerboGX. This is all located some distance (30m) away from my main energy meter and consumer unit, wired into a secondary CU in my garage.
I would like to implement PowerControl and PowerAssist.
Before we install an ET112 meter and a long Modbus run/Zigbee link across the property, is it possible to feed the Cerbo with a total power feed via MQTT? I have two devices on the other side of my house independently monitoring my total load already, feeding this KW and Total Current via MQTT to Home Assistant quite reliably. Is it possible to present this data to the Cerbo so that it can use it in its PowerControl calculations?
Many thanks
