Hi All,
Other than this everything else works fine. Today the weather was bad and MP is recharging the battery from the grid. My setup is 2x MP II running in single phase parallel setup. AC ignore is operated via general flag and assistant generator start/stop.
Anyone else is seeing that 214V * 33.1A = 3,53kW? AC loads 1,56kW + battery charger 1,58kW = 3,14kW. Another 136W goes to DC system (I have DC meter) so this is already off by few hundreds. However 214*33,1A = 7083,4W... which would be double what is shown.
I have double checked with shelly energy meter on that phase for AC in and I have real consumption of 3,45kW. Victron seems to be reporting double current however still reporting correct power. I do have external CT clamp on the AC in side connected to the master and it is checked in the configuration settings. It is also doing the same thing on the output with 214*23,6A = 1,56kW... that would be over 5kW. I thought maybe it reports DC amps but that's not adding up either.
Any clue what's going on?
Regards,
M.
