Hey, looking to install guimods via setuphelper, but I get the error below. Frankly I prefer to use the cli, but I cannot find docs on how to use the setuphelper command line or how to install VeCanSetup form same. Any insight? Thanks in advance!
Ah, also, for some reason, the current touch display setup is not reading the correct /dev/input/event ... Hoping that is resolved when I install guimods.
@4000000066997ab425e0bd3c VeCanSetup/setup: --- starting setup script v3.4 @4000000066997ab42dd1d9cc VeCanSetup/setup: Error: new configs not present - can't allow reinstall @4000000066997ab42e49a5c4 VeCanSetup/setup: must run setup script from command line and configure ports @4000000066997abf061ab4bc RpiDisplaySetup/setup: --- starting setup script v3.3 @4000000066997abf2b15694c RpiDisplaySetup/setup: ++ ERROR: no display specified - can't continue - run install from command line
