Context:
- on a boat, in sunny circumstances
- 4x 170Wp solar panel array (2x2 in series then parallel)
- 400Ah LifePO4 battery (70% state of charge)
- 1 100/50 MPPT
Without any warning, the Victron MPPT 100/50 between the solar panels and battery stops charging. The app is showing 0W and only 13V on the solar side. When I measure the disconnected solar cables, I get +/-50V; when I measure after I connect them to MPPT, I get 13V.
Tried the following without any success:
- use the bluetooth app to disable and enable the charger
- disconnect all MPPT cables and re-connected in the right order
- I have carefully checked and re-done all the wiring
I looked in the previous topics, but could not find any immediate answer. My guess is the unit must be faulty, right? Any suggestions for other things I could try to remedy this would be very welcome.
Thanks!
