I have an RV with 12 volt system comprising 12 6 volt 220 AH flooded 6v batteries in series, Victron 75/15 mppt controller with 200 watt panel and am adding the Smart Shunt 500 and a 1000 watt sine wave inverter with integrated auto transfer switch. Only for occasionally running TV or computer etc...
I understand that the negative battery side of shunt attaches directly to battery - pole. Normally what had been connected to the negative battery pole now connects to the shunt negative load.
When an inverter is also installed does the negative from the inverter connect to the shunt negative load as well or to the negative battery pole? I am thinking to the shunt if we wish to see the load the inverter draws from the battery
I believe this is a pretty simple setup and that I change nothing with the solar controller wiring.
Thank You
Mike
Halifax, Canada
