Regrettably, supporting firmware versions back to v2.7x had become a huge task with more than a few cases recently where the package didn't work properly with these older firmware versions. Nearly 70% of the systems are running the most recent firmware, with 15% only a couple of releases back. A little under 20% are running firmware prior to v3.00. In order to provide better support for the majority of systems in the field, I have removed support for Venus OS firmware prior to v3.10 from SetupHelper, GuiMods, TailscaleGX and ShutdownMonitor. I will continue to fully support the last three major releases of these packages (currently v3.1x, v3.2x, v3.3x and v3.4x) with feature additions and bug fixes.
For those that are running firmware prior to v3.10, I am providing a backward compatible version of SetupHelper, GuiMods, TailscaleGX and ShutdownMonitor. In order to install and run these packages, it is necessary to change the branch/tag to "preV3.10support" (no quotes). These firmware versions will not receive feature additions but if a serious bug is found, I will do my best to fix these.
RpiDisplaySetup, RpiGpioSetup, and VeCanSetup also include the preV3.10support branch however the version available via the branch/tag "latest" should continue to work at least for now.
Have a site with older ccgx. (Unable to do remote firmware update for the Quattro). It had older firmware, don’t recall version. Possibly 2.xx… which was working. But upgraded firmware 3.31 ever since the vrm has “no data” for most of vrm system widgets (total solar, ac consumption's, soc, few others).
