Sam Wood avatar image
Sam Wood asked
Ignore AC input 'active' in Quattro advanced settings (VenusOS menu)
I have multiple three phase systems consisting of CAN controlled lithium batteries and 10kVA or 15kVA quattros working in offgrid applications.
I have been using the the warm-up/cooldown autostart function since cooldown time has been added and this has worked well on systems but I now seem to have encountered a bug.
The ignore AC input flag will be active and input will be ignored despite the battery being empty, generator running and nothing set in the quattros config to cause this.
When resetting the VE bus the system reconnects but often only for a few minutes before ignoring again.
I have updated to the large image and manually forced the cerbo register for ignore AC from 1 to 0, the unit then starts to charge!
Is this a bug? Or am I missing something? This problem has only occured in the past month or so.
MultiPlus Quattro Inverter Chargerbug reportac ignore
