I am trying to poll the connected temperature sensor with the following python script but I got the following error.
What should I modify in order to get things working?
Thank you
root@einstein:~# cat relay.py
#!/usr/bin/python
import dbus
import dbus.service
bus = dbus.SystemBus()
temp =bus.get_object('com.victronenergy.temperature.adc_builtin0_7', '/com/victronenergy/temperature/adc_builtin0_7/Temperature')
print(temp.Introspect())
root@einstein:~# python relay.py
ERROR:dbus.proxies:Introspect error on :1.61:/com/victronenergy/temperature/adc_builtin0_7/Temperature: dbus.exceptions.DBusException: org.freedesktop.DBus.Error.UnknownObject:
Traceback (most recent call last):
File "relay.py", line 6, in <module>
File "/usr/lib/python3.8/site-packages/dbus/proxies.py", line 72, in __call__
return self._proxy_method(*args, **keywords)
File "/usr/lib/python3.8/site-packages/dbus/proxies.py", line 141, in __call__
return self._connection.call_blocking(self._named_service,
File "/usr/lib/python3.8/site-packages/dbus/connection.py", line 652, in call_blocking
reply_message = self.send_message_with_reply_and_block(
dbus.exceptions.DBusException: org.freedesktop.DBus.Error.UnknownObject: org.freedesktop.DBus.Error.UnknownObject
