Refer to the attached Multiplus settings (PDF)
Multiplus settings July 2 2024 1709.pdf
I'm using a Multiplus 24/2000
Back ground- yesterday I made changes to the M+ settings to make it switch from invert to grid once the battery voltage reaches 25.2 for 20 seconds. It switched when those conditions were met.
(my question is below the photos at the bottom)
Here are the changes;
Virtual switch Tab- Usage---->dedicated ignore AC input (selected)
Virtual switch Tab- VS options----->
Virtual switch Tab- Ignore AC input----->
This morning the batteries were at about 25.8 vdc and using VRM, I manually switched the M+ from "On" (grid) to "Inverter only". As the battery voltage dropped down to 25.0 vdc the M+ didn't switch to grid even though it was set to switch at 25.2vdc.
Why didn't the M+ automatically switch to grid? Any idea?
Thank you
