Good day, My system works as an AC Coupling battery. one external meter measures the HUAWEI PV inverter which is connected to the AC IN 1 branch. This meter is connected to USB #1 The second meter, the one I have a problem with, is the Carlo Gavazzi EM 530. This electricity meter is installed at the position of overflow into the distribution network. It is set to 200A measuring current transformers. This electricity meter is located on usb no. 2. Both electricity meters have the Baud rate, stop bit, and parity set correctly. the problem occurs when the system is started, so the EM530 grid electricity meter stops communicating after a while and there is a delay of several seconds to minutes when the system does not work. see the video. Is it possible that the CERBO GX element is bad? Converter? or it is a wrong setting. Thanks for the help, I'm already very clueless and spent dozens of hours on this problem..
