Greetings, fellow tweakers. I'm brand-new to Venus OS on a Pi 4B Rev 1.5 / 4 GB. I happily had the latest 6/27/24 large build (FW 3.34) up and running (without connected devices while I await my VE.Direct UART to USB-C adapter and cables), and connected to VRM. I had started up on a small portable battery for initial setup and figured a power failure would be a good early test, since this will live in my battery box and be powered therefrom.
I had reset the PIN from default to the one I use with my devices, and renamed the device.
Unfortunately, after the power failure (battery disconnect), I can no longer connect to the Venus OS device in VictronConnect. I've tried the PIN that I set, and it fails. I tried the default, and it hangs.
Is there a way to recover the installation? I can start over, of course, but since I will want to save history once I get devices connected, I'm hoping that there is a way to restore access without complete reset.
Thanks for any input,
