levisolartech avatar image
levisolartech asked
ESS Fronius Throttled
Screenshot_20240628_091342_VRM.jpgScreenshot_20240628_091007_VRM.jpgScreenshot_20240628_090954_VRM.jpgScreenshot_20240628_090945_VRM.jpgScreenshot_20240628_090933_VRM.jpgScreenshot_20240630_170342_VRM.jpg
I have a system that worked fine until 1 week ago. Although the batteries are discharged, the 2 Fronius are in throttled status, they are connected on AC OUTPUT of Victron. If i select to "keep batteries charged" the batteries will be charged from the grid without any problem. Also i noticed if the batteries are charged with 20A for example from PV and if i modified "pv feed in excess" to ON, the 2 Fronius will increase their power and all the pv production will go to the batteries/consumption ( from 20A to 80A example). What could be causing this?
dvcc - on
ess: AC feed in excess - OFF.
3 x Multiplus2 5000VA
2 x Fronius
6 x Pytes battery
ESSFronius
sean avatar image
sean answered ·
What is zero feed in power limit set to within the device settings of each Fronius ?
