I am having an issue with the internal temp warning and it’s doing my head in. Inverter is off overnight and I generally recharge by generator in the morning. I will switch to charge only and it will immediately go into internal temp warning then alarm. (Flash then solid). Same for inverter. Key points:
1. Temp of circuit board is around 30ºc so well within parameters
2. Circuit board is clean and free of dust.
3. System will randomly work ok. Last 2 day were fine. Today, not so much.
4. Disconnected battery temp sensor (I’d heard this can be a problem)
5. All connectors are clean and tight.
6. Fault occurs whether generator is on or off.
7. Battery voltage seems ok.
I have tried multiple configurations and seem to get the same error. I have read that I’m not the first with this problem but can find any actual solution. Any ideas would be greatly appreciated.
Cheers
