System is not calculating incoming solar. CCGX shows incoming and maintains batteries when an average idle usage of 250 watts. Current condition, MPPT floating, after evening draw the next day I'm pushing 750 solar watts until charged. Battery percentage stays at 0%. Screen shot from VRM remote console view.
Setup I have installed on my boat. Multiplus II, CCGX, MPPT, SmartShunt, fuse, 4 280Ah batteries, busbars and switch.
I've researched, changed the setup, but to no avail. Image is of my current setup. System charges and records properly when connected to shore power, except for solar.
Diagram=
Batteries wired parallel as labeled #1 to #2 to #3 to #4
Positive- Multiplus II to fuse to switch to busbar to battery #1. IP65 positive to #1 positive
Negative- Multilus II to IP65 to busbar to battery #4.
Tried to put as much info as I could here for easy diagnosis. I know it's simple but it has me stumped.
