I have BSC IP65 in my RV, that worked well for a year or two. From one day to the next one, it is not following it's settings anymore. No changes in wiring in between.
Just after connecting mains power, it starts to bulk charge, but with very low currents only (below 1A usually), while the battery voltage is clearly below all thresholds. After a minute or two, it is changing to absorption, with battery voltage still more than one Volt below the configured value.
Any ideas what went wrong here? I already tried a factory reset, followed by choosing a pre-configured battery type, but I did not see an obvious change in behavior.
