3 Victron Multiplus-II in 3 phase configuration will not start after power failure, battery is charged.
After night grid lost I cannot switch on any of them
This site is now in read-only archive mode. Please move all discussion, and create a new account at the new Victron Community site.
3 Victron MultiPlus-II 48V/5000VA/70A, MPPT 150 | 70 - Tr VE.Can (+ 6 panels AS-6 M144-HC 465W), MPPT 250 | 85 - Tr VE.Can (+ 8 panels) , Cerbo GX, ELERIX EX-S5 48V/5kWh, LiFePO4, BMS.
You have 15kVA of inverter running off that small (unsupported) battery that is never going to work well.
Start by checking what the BMS is reporting.
What are the restart parameters set on the inverters?
What errors did/does the GX report?
What firmware on the cerbo/inverters?
114 People are following this question.
