Hi forum,
I've got a Victron MPPT 75/15 (and other Victron elements) on my camper and it's been working fine for two years or more. It's connected to a 120Ah 12V AGM battery.
A few days ago, while preparing to take the camper away, I noticed...
Suddenly the MPPT controller was pushing 30V+ to the battery, and had been for the past couple of days, despite, as shown in the graph above, working fine beforehand.
Checking the settings in the app, the controller had set itself to 24V. Setting it back to 12V put the voltage back in the correct range but it was too late and the battery is cooked and won't hold charge.
I hadn't touched the app (or the camper for that matter, it was sat on my driveway and I was at work that day) the day the voltage changed, nobody else has the app installed for this installation, and the Bluetooth PIN is not the default one.
I've found one other thread ( https://community.victronenergy.com/questions/48449/why-mppt-is-overcharging.html ) which suggests that these controllers can reset the voltage to 24V by themselves. This seems dangerous.
Has anyone else experienced this? Is my MPPT faulty? Would you trust it with another battery? Or do I rip it out and put in something where I can set the voltage using an old-school jumper?
Thanks
