Hi. I've got victron smart solar 150 45s, and the manual states not to use optimised pv panels, or fit optimisers as it messes with the mppt and can damage the smart solar charger.
My question is:
How do I identify if a pv panel is optimised - is it always the case that the optimiser is a bolt on plug in box, as you see if you Google search Optimisers, or can the optimiser be built into the panel itself.
For example Longi - I have looked through their spec sheets and some allude to optimisation, but I cant figure for sure either way if they are smart panels, have bolt on optimisers, or just use the word optimise as a sales thing and are actually standard panels.
Thanks in advance
