I have standard Multiplus II system connected to the South African grid. The backup generator that I need to use does not meet the SA grid code parameters, so a change over switch does not work.
I can change the grid code to other, but then would need an anti islanding device.
I want to add a second Multiplus (set to other grid code) for the generator to be used as a charger. It would need to be connected via an MK3-USB interface.
What support is there in the Cerbo GX for this? Where would these details be shown?
Would more functionality be available if one connected the second Multiplus via VE.Can bus with a VE.Bus to VE.Can interface?
Can one access the second Multiplus in Node-RED?
