This easy solar device comes with 3 pairs of solar panel connectors, but I'm struggling to understand why.
I'm planning on putting this device into a motorhome with 3x200w 12V solar panels.
the MPTT 100/50 in the easy solar is rated to 700W. My plan is to wire all three panels in series to achieve a voltage around 45V, 13amps max, and 600w.
With this easy solar being 700w maximum you could only connect one panel to each point, but then what happens inside the easy solar... are they controlled by separate MPPT controllers to maximise output, is it 700W per connection, are they series or parallel inside the easy solar.
It makes sense if you are going to exceed the current rating of the connector but is this possible with a 700w limit?
Any help with understanding this is appreciated.
A
