So Everytime I use my air conditioner on battery (4x330ah lifepo4) I get a low battery/overload light for a split second when the compressor kicks in. Batteries show way above 13.5v
System has 2x 12/2000 multi in parallel so I can't see 50amps from the air con overloading it. Plus I'm using a soft start.
It doesn't happen when I'm on generator or shore power.
Anybody have advice on what's causing this?
