I have three MPPT chargers of which two are, as far as I can tell, identical. Same model, same configuration (using presets), same network, same firmware version, same circuit layout, same nominal PV capacity (although they are different brands).
Some days, one of them will not charge. It's always the same one ("XT PV charger"):
I have a breaker between the PV and the charger. If I open and close it, it will immediately start working normally:
It will keep working for the rest of the day, but the following morning it may or may not refuse to charge again - I could not detect a pattern.
What could be causing this?
