Hi all,
I just installed my new multiplus II GX and connected it to my wifi network. Works fine. Via wifi it is also connected to an openDTU and collects data from the DTU.
For the ESS setup I bought an EM24 ethernet (needed about 7-8m cable so i didn't get the rs485 version). I wanted to connect the EM24 ethernet to the ethernetport of the multiplus with a static and direct point to point connection. No routers, no inthernet and no other devices inside this network.
This also worked fine.
My Problem is now, when I start the Victron apperently it prioritieses the LAN conneciton over the WIFI (I found this also in the manual). Now I can't ping the multiplus anymore, can't get a ssh connection and the DTU data are not displayed anymore. As soon as i diconnect the LAN cable to the EM24 everything comes back.
Any Ideas how to solve that issue?
