We have 6 100Ah superpacks connected in parallel to a positive and negative busbar. After a brief low voltage event, a charge source was connected to the batteries but only three batteries are charging normally. Three batteries will not accept any charge. When disconnecting these batteries individually and checking the voltage, they seem to be fluctuating between 11 and 12.5 volts. After reconnecting them individually they do not accept any charge. The busbar voltage is now approx. 13.6 volts. Any suggestions on how to get these batteries to reconnect.
