genestoy avatar image
genestoy asked
Need help with Orion 12/12-18a settings
I have a Orion 12/12-18a installed in my travel trailer and would like some help with some "optimum" settings...
I have 2-100ah Lifepo4 batteries connected and have a DC refrigeration running that draws 4 amps. The Orion seems to maintain the batteries ok with the refrigerator running but seems to stop charging at 80% SOC and goes into float mode according to my Victron Smart Shunt. My GMC Yukon has a smart alternator and I have just been running the Orion with the factory default LFP settings and engine shutdown detection enabled as the Yukon keeps the 12v charge line active all the time.
I would like the Orion to keep charging at a higher rate so the batteries will go to 100% SOC?
Any suggestions as to some "User Defined" settings that may help would be appreciated.
Thanks
orion-tr smart
