Just a question regarding a 100w Solar panel that I've got connected to a 100/20 Victron smartsolar unit.
Voltage and current from the panel is 20.3, 5.13 on a multimeter.
However, looking on the app: The power output seldom reaches above 75W when charging. And the values settle at 17 ish volts with 4.5 ish amps.
Interestingly, when I initially fold the solar panel out, the controller values go all over the shop for a little while (see video). Voltage starting at 20ish Volts, then dropping.
Just wondered if there was someone more intelligent than I am that can make sense of it all. From my understanding the panel and cable is fine based on the multimeter reading. But I'm not sure why the controller is measuring values that are less than the multimeter - perhaps things change when a load is applied? And why I'm only ever getting 75W, not closer to 100W.
I'd be very grateful for any input!
