I have tried both models and have the same problem. The controller is connected to 12V 200Ah LiFePO4 battery, a 165W solar panel and a 12V Dometic CFX65DZ refrigerator connected to Output. The system works fine as long as the panel is providing power. With sunlight, the output to the refrigerator runs around 3.5A Once the sunlight goes away, the output is greatly reduced. It will allow LED lights that consume 0.1A, but not much more so the refrigerator turns off. The Trend graph shows the output amperage drops immediately when the solar power drops below roughly 25 watts. I have removed the jumper and have tried a variety of the output settings including Always On and the behavior is the same. When the refrigerator is connected directly to the battery, it's voltage doesn't drop below 13.1V after running all night. I have seen other people having this problem, but have not seen a solution.
