I am using two Multi in parallel and I'd like to understand the data displayed in the Multi 01- AC output voltage and Current of the VRM.
I see two values for voltage and two for amps, not sure if they relate to the two inverters or what, in this image namely 229.7V / 236.6V & 1.3A / 5.6A
If that is so there would be a load imbalance.
Thanks
