We want to expand our existing 2x300Ah LiFePO4 bank (2 years old) by adding another 300Ah battery from a different manufacturer. What is the simplest way to do this safely?
Details
On our boat we have 700W solar panels wiht Vitcion MPPT plus alternator with Balmar MC618 controller and a Victron 12/200 inverter (80A charger when on shore power) all running into two 300 Ah LiFePO4 batteries in parallel. Monitoring is via BT on the MPPT controllers and a SMArtSHunt on the bank. No other central BMS
In high summer we generate 300Ahday but use 400Ah with the aircon on. The idea of the extra battery is that we tank up on shore power when available and that will see us through 3 nights at anchor. Extra solar of alternator output is not an option. We could
1. Just parallel the third battery (not recommended)
2. Connect it via DC-DC charger - safe but we'd want it running in both directions (Victorn don;t make a bidirectional DC-DC charger thought there are some on the market from Sterling and Renogy.
3. Use a separate 230V-12V charger while on shore power to charge the third battery then a 9A DC-DC charger to trickle it into the main bank.
Thoughts or suggestions would be much appreciated!
